Thermwood 5 Axis High-Performance Heavy-Duty Model 90 Videos
The Multi-Purpose 90 is a heavy-duty five-axis designed for high-speed trimming and pattern machining, available in single or dual moving aluminum tables.  It is capable of full five axis simultaneous motions with extremely fast accelerations.
Thermwood Model 90 10'x5' 5 Axis CNC Router
Model 90 10'x5' Single Table
Thermwood Model 90 Dual Table 5'x12' 5 Axis CNC Router
Model 90 5'x12' DualTable
Available Features:
  • 12 HP 24,000 RPM Router with a 4 Position Automatic Tool Changing System (Standard)
  • 16 HP 24,000 RPM Router with a 4 Position Bar Style Automatic Tool Changing System (Optional)
  • 21.5 HP 24,000 RPM Router with a 4 Position Bar Style Automatic Tool Changing System (Optional)
  • 1" Thick Solid Aluminum Vacuum Table (Standard)
  • 1/2" Thick Multi-Function Vacuum Table (Optional)
  • Extended Z Axis: 36" vertical (Optional)
  • Extended Z Axis: 48" vertical (Optional)
  • Extended Z Axis: 60" vertical (Optional)
  • Six Position Tool Bar Under Gantry (Optional)
  • Four Position Automatic Tool Changer - On Right Side Gantry Leg (Standard)
  • Ten Position Rotary Automatic Tool Changer (Optional)
  • Twelve Position Tool Bar (mounted to back of table) (Optional)
  • Automatic Tool Length Sensor (Optional)
  • Automatic Lubrication System (Optional
  • Gantry Lighting System (Optional)
  • Accu-Lube Mist Coolant System (Optional)
  • Machine Enclosure (Optional)
  • Impact Resistant Five Axis Head (Standard)
  • Continuous C Axis (Optional)
  • QCore SuperControl
  • Free Lifetime Phone/Forum Support
More Info
